No power to coil
  • No power to coil
    im getting no power to the coil, main relay is fine, ignition key tumbler is fine, fuse is fine.. any suggestions ?
    Got the correct wiring diagram for your car? I would be probing the ignition switch to confirm power is going out when ignition is on.
      Check for fuel. If there is none AND there's no spark then it's most likely the crank position sensor, or, the ECU.
      Ron ///Man
      • '89 M3 M3T / ITR Club Racer
      • '94 Spec E36 - Eh....
      • '09 M3 - Tarmac Terrorist
      • '07 530 Xi - Highway Star
        I had no spark on an e28 525e recently (same 2 x sensors in bell housing) and I was getting power to the coil at 12+, but the coil was not being grounded by the ECU (signal). It was a faulty crank sensor. If he is not getting power to 12+ on the coil then its a wiring or ign switch issue....
          I found the problem, it was the on -board computer relay box, itís behind the ABS control box under the dash.. I jumped the green & green & red wire and it started right up.. Thanks for the replyís and Iím really grateful it didnít burn..
