Your Recommendations/Replacement Parts while Cylinder head is off
    There was nothing wrong with the old pistons, just that the cylinders are not exactly round. So he wants to bore +1. He said the old piston would work, but there would be a rattle with just new rings.
      If it were me, I would use aftermarket JE pistons and bump up the compression. 10:1 is too low. That's even lower than factory? If you want to use OEM BMW pistons, I would look at Evo 2 euro non cat pistons at +1 oversize, which will be found on ETK and bought through the dealer.
      Back when these were new, unleaded fuel had very poor octane level so all BMW engines were pretty low compression. Now fuel has higher octane so you can run higher comp with no issues. You will get some much needed torque by upping the comp. I would go to 11:1 or more.
        10.0:1 was what Johnnie said off the top of his head.
        10.5:1 is what I looked up
        So where would I find/part number for:
        Evo 2 euro non cat pistons at +1 oversize ? you said the dealer would know? I will stop by Seattle BMW, they are less than 2 miles from my house.
          A quick google search yielded this
          https://s14net.vbulletin.net/forum/s...ons-on-rebuilt
          As in the thread, the price for BMW pistons are super expensive, that's why if it were me I would use aftermarket.
            This is also useful for BMW piston part numbers:
            https://www.realoem.com/bmw/enUS/sho...diagId=11_4321
              OEM Mahle are 400 each
              CPs rattle sometimes JR at AFC said, Johnnie says the skirts are too short
              Johnnie is a JE dealer, and Markus mentioned JE to me
              So I getting JE 11.0:0 93.5 or 93.6
              Fyi, Johnnie says JE and Wiseco are made at the same place
              Getting new springs and valves.
              Got 284/276 Schrick camshafts
                What about injectors? do I need new/larger ones? or would the stock one be okay with the new camshafts and larger bore/compression?
                • #23
                  What camshafts? If anything but stock you must port the head. No use in bumping CR with cams and not porting the head. Itís where all the power is in the S14. Then you will need larger injectors, MaxxAn, and a good chip to match. Scope creep 101.
                  • #24
                    How did this turn out?
                    • #25
                      what a mess... The mechanic who was doing was taking apart and installing my engine, decided he had enough and wanted to do something else. While the motor was at the machine shop. The shop where he worked didn't tell me for 3 months. Took another 2 months for them to find another mechanic that knew how to work on our cars. Then the mechanic hurt his back. Can only work 3 hours a day. Oh it's still at the shop...
                      The good news? They said the will give me a discount. But I didn't get it in writing. They said they started the motor for the first time yesterday. He said he will be done next Tuesday.
                      I didn't want to take it half, in pieces to my brother's shop. Too many things could go wrong. I wouldn't have been able to blame them if something went wrong.
                      But I am having my brother do my rotors, brakes, exhaust and shocks when I get it back.
