2.3 Engine identification
  • 2.3 Engine identification
    I have had an S14 M3 engine sat in my garage for a fair number of years and am unsure what variation it is.
    Other than the 215bhp "234S2" part of the code, I was wondering if the last part determined it to be anything different to the normal 215 engine?
    Code stamped on the block is 234S201A
    Date stamp is 1990.
    Any info would be greatly appreciated.
    Regards, Paul.
    E30 M3 Sport Evolution Black
    E30 M3 Sport Evolution Red
    E30 M3 Evo II Red
    E30 M3 Evo II Blue
    E30 M3 195hp Black
    E30 318 is White
    E30 318 is Red
    from
    BMW Parts and Accessories
    Engine and Powerplant
    Identification Code
    Powerplant identification code Part number Engine type
    current old
    204EA 01 A 204E 01 A 11 00 1312551 S14 B20
    234EA 01 A M3/A 01 A 11 00 1316995 S14 B23
    234EA 02 A M3/A 11 00 1312271 E S14 B23
    234S1 01 A 234S 02 A 11 00 1312717 S14 B23
    234S2 01 A 234S 03 A 11 00 1316997 S14 B23
    254S1 01 A 54S 01 A 11 00 1316976 S14 B25
    Post wipes out my spaces, so it's not in columns.
      2.3 cranks use a nut on the crank pulley
      2.5 cranks use a bolt on the crank pulley
      www.ZeppieriMotorsport.com
      E30 M3 Rebuild Thread
        Thanks for the info guys, this I already knew. What I canít find is if it belonged to a 215 regular M3 or a Ravaglia, or??
        E30 M3 Evo II Red
        E30 M3 Evo II Blue
        E30 M3 195hp Black
        E30 318 is White
        E30 318 is Red
          is there no VIN sticker on the head?
          88 M3 Henna
          95 M3 Orange
          97 M3 Techno
            send the serial number of the block to BMW classic and they will match it up to a VIN#. That VIN# will tell you what you want to know. It is stamped on the flat section on top of where the starter mounts.
              Unfortunately not, I believe thatís on USA vehicles only?
              E30 M3 Evo II Red
              E30 M3 Evo II Blue
              E30 M3 195hp Black
              E30 318 is White
              E30 318 is Red
                Thank you. I have the serial numbers etc. Iíve already given that to a BLW dealer parts guy who had been in contact with BMW who said they canít help... so Iíve just messaged him
                about trying classic or tradition.
                E30 M3 Evo II Red
                E30 M3 Evo II Blue
                E30 M3 195hp Black
                E30 318 is White
                E30 318 is Red
                  https://www.bmwgroup-classic.com/con...icate_engl.pdf
                    It won't really make a difference as the engines were the same between those, apart from painted airbox and valve cover on Ravaglia/Cecotto vs regular M3 with 215 bhp.
                    I am not sure whether BMW Classic will give you the missing info with regards to chassis or engine numbers. They will confirm the numbers you give them as being how they have them listed in the archives (or not).
