Looking for some information on the offset of the rear rotor hats. I ordered a bbk from IE and the rotor hat wont seat all the way over the e brake shoes. Everything is pressed in and torqued down, the hat is bolted down to the hub but is leaving about 1.7mm of the ebrake shoe exposed. I measured the hats from the surface of the hat to the end at 52.3mm and was hoping that somebody can take a measurement of a oem rotor so I can verify that the part is either correct or not correct in sizing.
Rear Rotor hat question
http://ows-cdn.tecdoc.net/otto-zimme...ad8776cfb6f4aa
total height 65mm, rotorhat face thickness 7mm -> Inside "depth" 58mm
Originally posted by stevesingo View Post
And yes, 58mm depth is correct. And be aware that some shops use of the shelf hat blanks from Wilwood. Which explains why sometimes measurements are not always correct for the intended purpose.
I will answer in Finnish next time, it is my natural language
Then You know what it is like to read German and English for me
You seem to have taken my response differently from how I meant it to be.
I apologise should I have insulted you with me posting the sketch and dimensions of the rear brake disk. It was a genuine effort to clarify the answer you had given.
This was related to an earlier comment that my link led to a German site.
There are people who speak different languages in international forums.
Often the answer can be found on a foreign language site, which will require a little more effort.
