Hi All,
My Clutch pedal spring's plastic mount broke and sheared the 45 degree plastic fitting connecting the line from the reservoir to the clutch MS. Fortunately it happened while I was in the car and pressed the pedal down. The molder carpet was removed immediately and I dodged a bullet as the car's floor pan paint is still pristine. Unfortunately about 2-3 ounces of brake fluid is now soaked in to the foam padding under the molded carpet. That was Sunday, Sept 22nd. The carpet is now dry. There are no stains. Carpet looks dry and perfect, but I would not want to reinstall it without removing the dried up remnants of the brake fluid for fear of it corroding my floor pans.
I cannot find an upholstery shop or detailing shop that wants to risk steaming/shampooing the foam side of the carpet, saying that they cannot guarantee that the foam will not disintegrate. What are my options? Since the brake fluid is now dry, am I 'on the clock' to fix this? I was thinking of just getting a large tub and soaking the carpet in soap water and then clean water alternately a couple of times to remove the brake fluid. Anyone deal with this before?
Too bad a new carpet is NLA. Willing to pay DEARLY for a NEW Natur Carpet!
Thank you,
Narayan
Thank you,
Narayan
