Sport Evo Rear Spoiler Settings
  • Sport Evo Rear Spoiler Settings
    Hello,
    I recently purchased a OEM Sport Evo Rear Spoiler and gurney flap. I have a question about the flap settings. As I understand it, there are three positions
    1. Monza
    2. Normal
    3. Nurburgring
    On the spoiler, there are a total of 12 bolt holes and on the flap, there are 8. When I set the sopiler to Monza or Normal, I can use all (8) bolts. It appars that if I want to set it to Nurburgring, I would end up using only (4) bolts, which seems like it would not hold up to a high downforce. Is that correct or is there a different, more aggressive flap for the Nurburgring settings? i did some research on S14.net but couldn't find anything but photos of the three positions.
    Thanks!
    Sash K
    '88 BMW M3
    '72 BMW 3.0CS
    '04 330Xi 6-spd
    '90 Ford F-150 4WD
    Unless you are drastically exceeding DTM racing speeds of the early 90s through a rainstorm, I'm betting it'll perform as designed.
      At the end of the day, set it how you like it to look, unless you are racing the car you will never notice it at any setting, and if you are racing the car you just might notice it adds time to your laps because of the added drag.
      The Evo extension was a patch they did later in the car's racing lifespan to attempt to get more downforce out of a wing they already had homologated.
      The cost of the added flap at higher extensions was lots of drag. The Evo3 flap at full extension adds significant drag measurable drag in lap times when used on cars withoutt the 330+ hp of the Gruppe A cars.
      On the Gruppe A cars they had over 330HP to overcome that added drag and they were chasing every 1/10th of a second, as by the time the Evo3 homologations came online both Mercedes and Audi had really caught up to the E30M3 and had the M3s number.
      The car's real glory years were mostly all in the original homologation configuration (stock wing, 2.3 lites).
        Thank you guys for your input. Really appreciate it.
        I don’t really plan on racing the car at this time but do want to take it out to some track events.
        My concern is if the flap is set to the Nurburgring setting, I can only use 4 of the 8 hex bolts. Is this as intended? At higher speeds, do I risk damage to the flap since I cannot used the remaining 4 bolts?
        I have seen aftermarket spoilers with 16 bolt holes so that the flap can be set to the Nurburgring setting and use all 8 bolts.
        Sash K
        '88 BMW M3
        '72 BMW 3.0CS
        '04 330Xi 6-spd
        '90 Ford F-150 4WD
          what Jimmy said. for an occasional track day, it ain't gonna make a difference on a track what setting you have it on performance wise. so if you are uncomfortable with the mounting system, just put it on a setting with more bolts....
          88 M3 Henna
          95 M3 Orange
          97 M3 Techno
            mlytle Thanks for the comment. Appreciate it. Agree that it wont make a difference on the track in terms of performance. I will give it a test and see what happens.
            Sash K
            '88 BMW M3
            '72 BMW 3.0CS
            '04 330Xi 6-spd
            '90 Ford F-150 4WD
              good on ya for using the car as intended....on a track!!!!!!
              88 M3 Henna
              95 M3 Orange
              97 M3 Techno
                what if you do have 300+ HP but don't want to go to the typical huge aero wing (yet lol). Is there an appreciable downforce in high speed corners with it in the ring setting? My home track (VIR), has several very high speed (100mph+) sections (with a 2.3l and 200hp) where downforce would be appreciated, BUT there are two VERY long straights. Test and data log I guess lol
                  HANDBLT I guess I will be the test subject for this. Still seems a little odd that you can set the flap to Nurburgring setting and only use 4 bolts, while the other to settings use all eight.
                  Sash K
                  '88 BMW M3
                  '72 BMW 3.0CS
                  '04 330Xi 6-spd
                  '90 Ford F-150 4WD
                    There is some data in the SIG archives on this.
                    Years ago when the car was still being actively club raced some Northeast track guys did some testing of all the wing settings (and no wing at all).
                    Its been a few years since I read it, the test was done at Watkins Glen (similar to VIR in many ways) the test car actually slowed down the more wing they put in.
                    I think the fastest lap times were with the wing completely removed (at the cost of driver confidence), so what I remember was the take away was that leave the wing on, but add as little flap as possible because it adds alot of drag.
                    When I had my stock wing type I think I ran it in the middle setting, the car felt good, but I knew from reading those posts that I was probably giving something up on the straights.
                      That's been my experience as well. I used to keep my flap in the middle setting. One day at Mosport I noticed one of the bolts loose so I decided to remove the flap entirety and my lap times improved. Entry to turn 8 was very sketchy thought.
                        I actually lowered the wing height before my last track day and there's a high speed turn that also drops a good 10 feet and the car felt loose. Next time I go back I'll raise it again and see if I get the same feeling.
                          In my younger days, I played a lot of college soccer. There was a lot of attention from girls, I dated a cheerleader captain. I planned to go on to professional sports after graduating from college. But fate had other plans.
                            I'll bet you were a ginormous POS douche bag as well.
                            1990 M3
                              Haha, that is a certainty.
                              1984 E30 323i Euro (sold)
                              1985 E30 325e (sold)
                              1988 E30 Henna/Black 2.5L
                              1988 E30 Macao Evo2 #330
                              2014 F31 328i Sportswagon
                              2017 F80 M3
