PLUG & PLAY STANDALONE
  • PLUG & PLAY STANDALONE
    Hi everyone. I have decided to go with a plug & play standalone system for my car. Moreover, i want to add the carbon intake and etc. I am not going with ALPHA system and am not looking for advice to steer me otherwise.
    Just want to know, who "still" carries this units and what additional setup I will need.
    Thank you,
    Michael
    There is no such system I am aware of for the S14.
    Anything stand alone will be a one off custom install and require bespoke wiring harness and tuning to varying degrees.
    Any deviation from the Motronic / AFM system will require varying degrees of tuning and wiring work.
    The only system that was close to "plug and play" was the old (circa 1998-99) Cyntex / Conforti / Racing Dynamics chip AN "if" you had a bone stock 2.3.
    The install could be done in about 30 - 45 minutes if you knew what you were doing.
    I dont know what the ALPHA system is you are referring to, if you are referring to Alpha N, thats a management method not a brand.
      Buy MS3 PRO and don't look back. Many know how to tune this system
      E30M3 is a Legend
