There are videos on YouTube if you search under E30 rear wheel bearing change. There are some items from your local hardware that will make the job easier. That's what I did when I changed mine.
I've done this numerous times with the Harbor Freight bearing kit and a special Ford FWD axle puller tool. Makes installing the axle back into the hub a breeze.
