Electronic Dampers for our Cars?
  • Electronic Dampers for our Cars?
    As my project car is nearing completion and has the latest Can Bus wiring and ECU technology, I was wondering in KW or similar do a system for our cars? I see they do them for other models, but no luck in the E30. Has anyone else considered this option?
    Toby
    E30 87 - S14 Turbo
    E34 90 - M5
    New BMW & Mini OEM parts - www.bmminiparts.com
    E36 or E46? I think the E90 dampers will go into the E46 housings with E36 control arms. maybe they have something for the E90?
      E30 m3
      Toby
      E30 87 - S14 Turbo
      E34 90 - M5
        Bilstein has a coilover DampTronic setup (EDC in BMW speak).
        https://www.ecstuning.com/b-bilstein...49-237108~bil/
        Of course, you'll need a controller and, ideally, a way to program them to suit your car.
          I spoke to Bilstien here in the UK and they don't have any for the E30 M3. It would require a control unit too. If the controller was using Can Bus system, I coukd fit it to my car.
          Toby
          E30 87 - S14 Turbo
          E34 90 - M5
            I have a period system by Koni in my car. It has 4 damper (rebound) settings selectable through a dash mounted button (and LEDs telling the setting) and uses the same technology as supplied by Koni to Maserati in the eighties.
            It was a special suspension package by Koni for the E30 M3 of which they built only a dozen or so as was told to me when I rang Koni technical support about it a few years ago.
            Springs in that package are Koni's own green lowering springs p/n 1048 Front and 1049 rear.
            It's a fast road oriented package and very capable.
            Full technical description:
            http://www.maserati-alfieri.co.uk/alfieri292.htm
            Would consider selling it if the price is right (think half of what a bilstein damptronic system would cost)
            I'm located in Germany, PM me if you're interested
              Shocked that it never took off koni way ahead of its time
              Mike
