Hey guys,
A while back, my tachometer would stop along with OBC displaying blank only backlight, it would then spring into action later.
After a while, it just stopped completely and didnt work again. So i checked the related fuses, all good.
Then i removed the cluster, put new batteries, no dice.
Then i put a different SI board, then another SI board, then another coding plug, then another cluster from a 325i, but no luck on the tachometer or OBC.
I checked with a multimeter pin #7 on the blue connector, it showed a value that goes up with the rpm, so the signal is there and seems working.
Any ideas what might be the problem? I'm going to open up the fusebox and see if anything is shorted there maybe
