the cables came loose from the connectors themselves? Then I would pin out the connectors from the connector housing, buy new connectors, crimp them on the cables, then put the connectors back in the housing. I would recommend to crimp new ones on and not to solder something there since the engine vibration may damage the solders. Regards, Nils
