Hey Guys.
I could do with a bit of help please. I purchased my car off an auction site back in October and have been assured that the engine that is in the car has been put together around 600 miles. The last owner broke the engine in steady for 500 miles and then ran it for another 100 miles. The engine has a limiter on it which is set at 6000 rpm. However after we have fixed a few other long time storage related issues such as brakes, suspension, ill fitting exhaust etc, I would like to take it to a specialist to get tuned.
The spec of the engine is as follows:-
S14 2.5ltr block - Lightened & Balanced crank
Extra Webbing & cooling oil jets
Arrow Precision Rods
JE Forged Pistons
Group A style Head
312/292 motorsport cams
38.5/32.5 Sodium Filled Exhaust Valves
29.5 ports
SRD7 Springs
48mm throttle bodies
50/55 4 into 2 evo 3 manifold.
Compression Ratio 12.0:1
Carbon Fibre Airbox 18cm runners
Maxx Alpha N ECU
Any help or advice you can give will be greatly received, it would be helpful to know what to expect from the engine, expected rpm ceiling with this spec & who you would recommend to tune it.
May thanks
JE Forged Pistons
Group A style Head
29.5 ports
SRD7 Springs
Maxx Alpha N ECU
May thanks
