89 Zinno Nut & Bolt Restoration
  • 89 Zinno Nut & Bolt Restoration
    It's been awhile since I've started a build-thread on a forum but I sure do miss them. (Long time gtrlife, nasioc, audizine and 6speeder) I find myself constantly browsing old threads and hoping to find pictures that are still hosted but unfortunately lost in the photobucket era.
    Bit of a backstory. I worked with a gentleman for 8-9yrs (2009-2018)and throughout this period of time he'd mentioned his E30 M3 that he purchased in 2001. Over time we discussed the car and I found out that he had parked the vehicle in ~08 roughly 3k miles after the timing chain and tensioners had been replaced. I tried to purchase the car back in 2015, 2016 and every year after I always ran into him and said "if you ever are ready to sell, please let me know".
    Fast forward to the beginning of 2020, Covid had just started. I'd left the previous company and moved from Eastern WA over to Seattle back in 2018. I receive a message on Facebook from my old co-worker, simply stating, " Are you Ready?"... I instantly knew what it meant! Couldn't hold my excitement, said "YES"! Low and behold he needed the garage space for a new project and it was time to move it on to someone else to enjoy. We reached an agreement and I sent a flat-bed 3hrs back to Eastern, WA to pickup my new to me, M3! Work from home? ton of extra time on my hands, quickly went from "get her running" to a full on nut & bolt restoration. Fun fact, I've yet to ride in and/or drive an E30 M3..
    1989 Zinno M3 145k on the clock that hasn't been driven since 2008.
    Down the rabbit-hole, Alice.. who's coming with me?
    2yrs outside and then another 8yrs hibernating in the garage at the PO:
    Sprinkler and 100+ deg heat had its way on this side along with passenger door lock was frozen
    Excited to see all the factory spares including the NLA Gray Carpet and factory radio
    No visible bubbling around the cowl!?
    Interior shot for 145k Miles seemed to be in fantastic shape!
    Factory Spare and wheel in amazing condition!
    Strapped up and headed to Seattle!
    Arrived home safe and sound!
    Once home, this is what I found
    in the garage getting acquainted!
    Very dirty, very dusty and LOTS of spiders... and Wasps.. and.... ya.. I screamed while pulling under-trays a few times.
    Here's the cowl which wasn't bad for the age, luckily drain holes seemed unaffected.
    couple small pinholes but luckily not bad compared to most I've seen
      Due to Previous owner parking due to motor noises and unknown shops troubleshooting the issue 10yrs ago I decided to simply ensure the motor was not seized, tossed in some Marvel mystery oil into each cylinder. 24hr later I put into gear and rocked the car back and forth and the Crank moved!
      Woohoo, fuel-relay removed (10yr old fuel in the tank), I attempted to crank the car. Fresh battery went in, everything came to life and it cranked over! No crazy interference noises that I could hear so out comes the motor so it can start the refresh process. Unfortunately fuel was not drained when he parked it back in 08... So pop open the tank and this is what we're greeted with.
      Sending unit
      Rust for days :(
      Out comes the tank
      I caved and started accumulating parts as I was tearing things down so I had some light at the end of the tunnel, LOL
      New Fuel tank, Sending unit, basket, and all rubber lines ordered for re-install!
        This is exciting. Cant wait for more.
        *See also Mlytle's thread unearthing a ~30K mile car that sat for decade(s).
          Thanks Jimmy! Will try to keep this updated as I go! Have about 8mos of content to toss up so should be some entertainment!
          New Spectra tank with Fresh Powder to match the factory tank. (one of the few non-oem parts purchased)
          Pulled the valve cover off, everything looked ok from what little I could see/tell
          Bumper removed
          Exhaust off (Holy cow doing this solo was a BAD idea..I do NOT want to put this back on the car just from a Weight POV!)
          Disgusting.. All of this was removed, new bracket, new filters and rubber isolators.
          It was at this point while dismantling things the "while you're in there bug bit" but let's be honest.. Every piece of rubber on this car needs to be replaced at this age.. Suspension received a complete overhaul via KW Coilovers while I wrapped the factory suspension up for safekeeping so they can go with the car if It were to ever be sold.
          New Diff Cover & Evo Flywheel
            Yes.. I am actually attempting to do this in a single-bay.. I eventually upgrade my lift system to a Quickjack setup which was mostly a good purchase. Hinders your ability to work on items due to lifting points but for the most part its been awesone.
            Time to start pulling the motor out?
            Bout ready to go
            Out she comes!.. Quickjack didn't give me enough room to drop the subframe/motor so I yanked it out with the trans attached.
            Voila..
              Empty bay! Now to start cleaning up or justifying the " maybe I should just paint the whole car "
              Gross.. Just nasty
              Trans
              Sachs Clutch (good sign)
              Off to the Machine Shop/Builder for a complete Valve cover>Oil Pan Refresh
                Wow, epic! Welcome aboard and I’m excited to watch your progress!
                1989 Lachs
                1988 Lachs - sold
                1988 DS - sold
                Car blog
                Bay Area M3 FB group
                  I love these threads and I was hoping you'd start one.
                  That looks like a great restoration candidate. Seems like it was well loved at one time but unfortunately neglected for a decade. That's much better than starting with a car that's been through lots of owners and has been hacked up with questionable repairs and countless stereo upgrades.
                  I'm looking forward to updates.
                    Thanks Mick! Very well loved is an understatement. I promised the PO I'd drive her back home and take him for a ride when finished.
                    After further inspection of the car and being told "no paintwork", the passenger door and rear quarter had been resprayed as I found the cutline in the door frame. I was going back and forth on repainting the car but really wanted to restore the factory single-stage. After realizing the car already had paintwork, the decision was much easier to go forward with a complete windows-out, respray. Also another rabbit-hole that I gladly climbed into.
                    Engine out, at machine shop.. Time to strip the car down for a respray.
                    Windshield out to assess Cowl rust:
                    Success!
                    Not horrible, expected worse to be honest. The Dry desert climate really helped with corrosion
                    Pitting that will be welded and entire windshield frame POR15'd
                    Lets get strippin
                      You all know the drill.. dismantle, bag it, label it, toss into the bin. I wind up setting up an in-home Zinc Plating Setup and media blaster.. It gets fun!
                      Rear side glass out
                      Pulled the ABS unit to send off to Jordan at Mtechnique
                      These must be one-time use? I had no way of saving most
                      You wind up with this.. Was able to save all of the trim except for the main rain gutters on each side.. I may have lost my patience and ripped a side off....
                      Sweet! more bees
                      Engine bay progress
                        Realizing I had to get the car back into a "roller" for the body shop I went ahead and refinished the Front Subframe, reinforcement brackets welded in and re-powder coated.
                        New Axles going in
                        Rear Wheel Bearings
                        Added the circlip and those were taken care of!
                        KW's tossed on in the rear along with new rotors and e-brake shoes. (It was here I should have just removed the rear subframe because I get to do all of this again when the car is back from the body-shop to finish the subframe bushings
                        Off to the front end!
                          Out with the old
                          New Wheel bearings and fresh zinc coated ABS ring
                          KW installed
                          Much better
                          Door glass removed
                          Dash removed (no cracks!)
                            Here it is heading up to Arlington, WA to the talented guys at JMI
                            With the car gone and motor gone, I shifted my focus towards Zinc Plating all original hardware if it was reusable. Brackets, Calipers, bolts, etc were all going to be ultrasonic cleaned, glass bead blasted or vapor honed and then Zinc plated along with Yellow chromate to mimic the factory Cadmium from BMW in the late 80's.
                            Pardon the cluttered garage got to work with what I have!
                            Enter Walter White:
                            Bolts
                            Finished
                            Before
                            After blasting
                            Zinc'd & Chromated
                              What's the timeline here, is this project done and we're reliving your fun and pain in retrospect? Either way keep it coming.
                              Too bad about the rain gutters. As far as I know those are NLA. Let me know if you source them.
