89 Zinno Nut & Bolt Restoration
    Brake Caliper Rebuild
    Fun...
    Bead blasted and then Vapor-Honed
    Fresh Zinc before the Chromate
    Voila
      Originally posted by Mick View Post
      What's the timeline here, is this project done and we're reliving your fun and pain in retrospect? Either way keep it coming.
      Too bad about the rain gutters. As far as I know those are NLA. Let me know if you source them.
      Relived my first 8mos of pain with the car in 2020. We're about current now with some more pics to come. The rain gutters appear to be available but roughly ~260/ea side :(
      Current status of the car as today
      Panels Primed
      Body is up next!
      Cowl Repaired
        Motor came back from the shop.. unfortunately I had to send it back as the O-rings I ordered for the lower timing guide came back uninstalled, sealed in bag from BMW......
        Started to add accesories and then I found the missing o-rings
        More freshly plated goodies and bolts
        Chased the threads for exhaust stud install
        Timeserted the starter based on many recommendations on S14.net!
          Freshly rebuilt starter installed Above ^^
          PS Pump and AC Compressor came back from Jay Stratton and they're pieces of art!
          Original
          Restored
          PS Pump
            Pretty wild to see the sludge inside of the old ABS pump!
            Before/After
            Sludge from MY old pump 145k miles
            Glad I went ahead and had this redone, hats off to Jordan as his work is absolutely top-notch!
              That ABS sludge makes me wish I had sent mine out, yikes!
              Assuming you're going with a CF box, you're going to need to rotate your dipstick another 45 clockwise. It should peek out above your alternator. Example:
              https://s14net.vbulletin.net/forum/s...60#post1298760
                I have a carbon plenum but it is OEM replica that I may toss on but no Alpha-N Carbon box so I wasn't sure if I'd still need to rotate it or not but I did read that. Sadly I've removed it all as the motor is back for the o-ring install. I have my older rubber blocks for the intake manifold. Is there a tell-tale way of determining if they need to be replaced? They seem to be NLA so wasn't sure the preferred method for the TB gasket/rubber block?
                Chris
                • #23
                  Omg your awesome if you feel like doing it again I will supply an apartment and a car to use site see NYC and do my car !!!
                  great work Mike
                  • #24
                    Some more Zinc fun, inner door handle/lock releases
                    Completed
                    "some" of the assorted hardware arrived thanks to Paul at Maximillian!
                    Throughout the process, I've been accumulating a few to many sets of wheels... wife thinks its an addiction which she isn't "wrong"..
                    17x8 ACS
                    BBS RS212
                    Set of TE37's because I'm a JDM guy at heart
                    aaaaand... these.. I swear I'm done buying wheels for this car I've yet to drive.. :/
                    • #25
                      I’m serious
                      • #26
                        Trying to figure out what to do with this next..
                        Might send it to Jordan or I might just re-wrap what's there and call it good as the harness in in great shape aside from some heat-tubing that is very brittle.
                        • #27
                          great work Mike
                          Hah! Thank you, Mike.. I need to get through this first one! I will say this process of going front>back and truly touching each nut/bolt has been a very rewarding experience. I think everyone knows how quickly projects spiral out of control and you all get front-row seats. Once the car is back from paint the rear subframe gets pulled and the underbody gets a thorough detail & wash prior to the "rebuilding".
                          Will post a few more pics as I have loads of parts that I've accumulated but will let the dust settle and hopefully everyone enjoys. Sorry as it is picture heavy
                          Chris
                          • #28
                            I don't know the answer to the TB block question and didn't realize they are now NLA. That sucks.
                            Love the TE37s. What size and offset are they? When your wife is ready to throw you out of the house I'll buy em.
                            • #29
                              Bahaha.. That may be sooner than I'm expecting.. 17x8.5 +15
                              These were one of the remaining sets left as the molds were supposedly trashed. However it looks like they're resurrecting the mold and may be able to order a set again from Volk as they have a new ETA of 2021?!
                              • #30
                                Excellent work and the plating looks superb.
                                The harness is easy as, lay it out in the sun then photo and de-tape and clean it all down with meths inspect the terminals and connections and apply new cloth tape correct type not the under dash tape.
