89 Zinno Nut & Bolt Restoration
  • #31
    Originally posted by dudley123 View Post
    Bahaha.. That may be sooner than I'm expecting.. 17x8.5 +15
    That's great that they don't need spacers. Someday I need to transition my track car to 17" wheels and have been casually looking for the perfect wheel. Ideally they would be 17x8, but 8.5 is close enough and those would look rad. Since I'd need to buy 4 sets cost would be an issue though :| I assume these are nowhere near the $250/wheel range that the Apex ARC-8's are. Haha
    • #32
      Yessir! That was my goal, no spacers. I love the ARC-8's and the cost you cannot touch as you know. Unfortunately, yes, the TE's are ~750/wheel I believe.
      • #33
        nice work. you're doing the job that i wish i could afford to do to mine. thanks for sharing.
        Portland, Oregon
        '88 M5 | '88 330is | '89 M3
        • #34
          Here are some pics from the Intake Manifold rebuild.
          Quite a bit of built-up grime. Pulled the throttle plates, springs, ordered new Sealed SKF needle bearings thanks to Brandons write-up on here.
          I took a ton of pictures so I'd remember how everything went back together as there are a lot of spacers, springs and doo-dads. Take special care removing the throttle plate screws as they're staked from the factory. I was able to remove them without much hassle but remember to debur on re-install as I've yet to find any suitable replacements. quick Dab of red loctite on each one and I re-staked as best I could. Need to ensure you do not bend the bar when re-staking so special care in providing support from underneath is needed.
          One Vapor honed vs original
          All Finished
          • #35
            Had the Alternator rebuilt and restore and zinc'd the pieces.
            Fresh zinc'd pulley, blasted case and plated fan!
            • #36
              Hi, your work is Looking very good.
              Did you reuse the throttle screws and did it pose any problems unscrewing them and what tooling did you used to extract the throttle shaft bearing.
              Thanks.
              Dave
              • #37
                Thanks.
                Dave
                Thanks Dave!
                was able to reuse the throttle screws. It was tight removing them but I was able to remove, chased the threads and all was good. I was a bit nervous not going to lie but all seemed to go back together just fine.
                I used a small blind hole bearing remover. (slide hammer)
                • #38
                  Nice work, throttles came up nice! I’m going to tackle this soon too so some good tips here.
                  • #39
                    God I miss build threads like this. Nice work, can’t wait to see it completed!
                    • #40
                      Hah! Yes, I miss them as well. FB posts are great you can't follow along which makes finding any info beyond miserable. I wish we had more traffic on S14 as I'm sure back in the day but I'm thankful for the wealth of info I can glean from others build threads!
                      • #41
                        After purchasing a replica Sport Evo wing after many saying it was fine, I quickly realized my initial concerns were true.. It didn't fit right, nor did the OEM Gurney flap. I'm sure it could have been massaged but at this point in the process and how far I've already gone... I pulled the trigger.
                        OEM Sport Evo w/Flap
                        Went up to the body shop to drop off the wing and snapped a few pictures of the current stage. Sounds like paint goes down next week! Hoping to throw a gopro in the booth for a video, hopefully more to come
                        Plan is to mimic the factory spray pattern behind the fenders and underbody and fade in a bit of overspray on certain spots.
                        Excited but also nervous as the reality of re-assembly is setting in and doing so without scratching anything is going to be a nightmare me thinks..
                        • #42
                          A couple nicks here and there will just make you feel better about driving it. Amazing work so far. The pursuit of perfection is futile, and it doesn't need to be there to be absolutely amazing!
                          • #43
                            agree with this, im so anal and it just means you end up with a museum piece to look at not drive and enjoy. I have to come to terms with what im doing now with the restoration might need to be redone in 5 years or so
                            • #44
                              I love the commitment! Very keen to hear what you think about the KW's - they seem like a great option to replace the factory strut
                              JUNGL3
                              333i Sport - Alpina M52 3.3, E30 M3 5 Stud
                              • #45
                                Me too. They’ve been out a while but I haven’t really seen any informative feedback here or on Facebox.
                                1989 Lachs
                                1988 Lachs - sold
                                1988 DS - sold
                                Car blog
                                Bay Area M3 FB group
