On borrowed time?
  • On borrowed time?
    I got an UOA from Blackstone labs and am quite bummed by the results. The motor is stock with a TMS baffle and has only 70xxx miles and 2700 miles on the M1 15w50 with an oem filter.
    IRON 26ppm
    COPPER 192ppm
    LEAD 139ppm
    I realize that the rod bearing are going to need to be done asap. My question is with the IRON reading should I be worried about a scored crank?
    While I am in there should I replace the oil pump? If so US or E3?
    Looks like I am missing a DE on the 20-21 at WGI :sosad:
    -kevin
    How is the compression and leakdown? If they're fine I wouldn;t worry about it.
    You can drop the pan and replace the lower bearings for cheap insurance.
      I think you really have to look at a trend to really know what's going on. If your copper amount is constant then it must be there because of some other factor, not wearing bearings. That being said I would drive it easy until the next oil analysis
        Thanks Alpine, I guess I will take it easy for a while. Just bummed about the DE.
        -kevin
          Kevin,
          Did you inspect what came out of the oil filter? When I trashed my rod bearings, my oil was full of copper flecks. They could be seen with a flash light but not felt when rubbed between the fingers. IMHO, all S14er's should do this at every oil change.
          -Dietrich
            if you are suprised because you have low mileage, dont necessarily be suprised.
            when its time to do bearings depends heavily on use and how the car was treated, not just
            mileage. lots of cold starts, reving to fast before warm, and one of the biggest killers:
            starting up after months of storage without building oil pressure first.
            people get so hung up on high rpm. high rpm is ok, regardless
            of what the local chevy budies might say. they dont have
            the same motor. the largest amount of wear comes within the
            initial moments of start. you can change your oil every
            500 miles and it wont change this fact.
              Dietrich,
              Unfortunately, I did not get to look at only my oil. I drained it into the oil my brother had just drained from his car and also the tranny fluid from my fathers car. :rolleyes:
              I am going to change it again in a few hundred more miles and take a very close look at it. I only have about 600 on it currently. Was your crank trashed already when you had flecks of copper in your oil?
              John,
              I am not necessarily shocked by the low milage. I understand many consider rod bearings to be a wear item. I guess I wil have to see what the next oil change brings.
              -kevin
                i cant speak for Dietrich experience, but I can tell you that when it get to the point where you
                can see the copper flakes, the rods are often out of round. this damages the crank journal
                in the process. the result is that you need new rods and crank or have to refurbish them.
                you can slap in new rod bearings and in street usage they might last another 20k, but under
                track use they will degrade very quickly and you are back to square one.
                it doesnt have to be this way, but it often is.
                  Kevin,
                  I believe my crank was scored. It looked like it to me, but I'm not an engine builder. I rebuilt to a 2.5 anyway. Also, my upper bearing on cylinder four came out in 3 pieces. It wasn't pretty, but oddly, the car ran fine - just had what was thought to be valve clatter - but it may have been rod knock. If you have copper flecks, John's right, things are bad.
                  -Dietrich
                    ......so.. how do you build oil presure before start up?
                      by hand
                        Accusump. VAC motorsports can set you up with one.
                          will the accusump build pressure after car has sat for a long period of time?
                          PS: the traditional method (when a car has
                          sat some time) is to pull out the spark plugs,
                          pull main relay, and turn the motor over
                          on the starter until oi light goes out.
                            Is it just as safe/effective to crank the engine with the CODE set?
                              Using the code feature does the same thing - stops fuel injection. You should pull the plugs b/c it will allow the engine to spin at approx 2k rpm without the forces on the crank associated with compression. This also builds pressure more quickly.
                              -Dietrich
