C pillar trim install...
  • C pillar trim install...
    How is this meant to be done? The front of mine is still connected to the window strip and I can not for the life of me get the metal tabs into the clips! Any tips?
    MIne went on relatively easily. I placed both clips on the metal bar (attached behind the C pillar) and then carefully watched/lined up the clips to bite onto the frame. Then quick snug push/pop and then went on. It almost looks as if the clips are attached to the Plastic portion? If so that is incorrect.
    Picture here: https://s14net.vbulletin.net/filedat...4&d=1349127261
      Thanks. Nah that's the same as mine. Pic is looking down through rear window. Does the parcel shelf need to come out?
        Possibly. I reinstalled the pillar trim prior to the parcel shelf so maybe that was why it was easier?
