My low pitch horn decided to abandon ship and flew off at speed. Anyone know the PN for the 1. Horn, 2. connector and 3. bracket? Thanks!
Low Pitch Horn P/N and Connector PN
The plastic connector is 61131378416.
If you need new pigtails they're either 61130007446 (heavy gauge) or 61130007445 (light gauge). The only difference between the two is the gauge of the wire, I don't know which the horn used.
The bracket is part of the horn assembly. Part numbers can be found here
https://www.realoem.com/bmw/enUS/showparts?id=1003-USA-09-1989-E30-BMW-M3&diagId=61_0959#61331376189BMW parts 3' E30 M3 Diagram Selection
Hi are you sure it is not the OBC horn if yes p/n bracket is needed. I recently repaired an M3 where the OBC horn bracket broke off taking the horn and wire plug with it, the bracket was on the L/H side below the headlight area.
