Hi everybody. It’s my first time posting on this site. So please bear with me. I just recently had my 2.3 S14 motor rebuilt. I use the Turner Motorsport 2.5 stroker kit. I also put in the performance Schrick cams and spring. Has anybody have use this kit before? And if so did you have any problems with it?
So here’s my problem. The motor will not idle correctly. It’s idols at like 650 RPM. Just on the verge of stalling. I have replaced everything on the motor. Everything is new. New idle control valve, fuel pump, fuel regulator, all the rubber fuel lines and fuel filter. I have a new distributor cap and rotor by Bosch. I have new spark plug wires and new plugs.
For some reason I cannot get the car to idle correctly. When you first started up it idles fine for about a minute. Then the idle drops down to about 650 RPM. Just on the verge of stalling. I tried adjusting the idle valve that is in between the throttle bodies. It does absolutely nothing. You screw it all the way in and then screwed all the way out. And nothing changes.
Has anybody ever had this problem before? If so can you please share your fix on it.
thank you
Christoph
thank you
Christoph
