Hi all,
II know it is a topic already dealt with but I thought that every engine with different specs has requirements
mi evo 2 after rebuild engine:
2.3 cc
Evo 2 TB
11.5 mahle motorsport , (with pocket)
Valve m5, 38,5
50/50 Evo2 collector with supersprint street
In port head 29.5 mm (by John)
Schrick street springs,
Cams: 284 and 264. (104-100),
Evo 3 injectors 300cc
Alpha N, airbox.
New oil pump
New water pump
New full distribution
I got 254 hp on dyno now the car has great strength even at mid-range !!!
I want to move on to the next step in the cams. 274 ex in your opinion is it worth it or is it better to leave 264?
would the difference be minimal ?
if i should also increase the fuel pressure or are the evo 3 injectors enough?
what timing you reccomended ?
P.S I state that I have decided not to go for the schrick 292
thank you
2.3 cc
Evo 2 TB
Valve m5, 38,5
Alpha N, airbox.
New oil pump
New water pump
thank you
