Electric fan setup/wiring.
  • Electric fan setup/wiring.
    Hi. I recently purchased an M3 that has an electric fan, and "rongineering" electric fan kit (activates fan 5 seconds after brake pedal is pressed). The viscous fan is deleted, I have a CSF aluminum radiator and there is no fan shroud. Sometimes the temp creeps up above half but never over 3/4 when idling.
    I'm thinking of wiring the electric fan with a coolant temperature switch. Any recommendations on this setup (what temperature coolant fan switch, where to mount the coolant fan switch, there is a spot on the thermostat available and 2 spots on the bottom of the radiator on the drivers side)
    Do you think I should install a fan shroud??
    Thanks in advance.
    VAC Motorsports sells a nice kit with relay’d wiring harness, an 88*C ‘low temp’ fan switch, and brackets. I think they sell the harness / fan switch sensor searately.
    I mounted mine in the bottom of the thermostat housing and it all works perfectly. Using the included 14” SPAL puller fan with integrated blade guard doesnt require a shroud however if your current elec fan is unprotected a shroud is very nice to have.
      what am i missing....why would a fan be set up to come on when the brake pedal is pushed?
      it should be connected to a switch mounted in the the T-stat.
      88 M3 Henna
      95 M3 Orange
      97 M3 Techno
        OK so I am not the only one that made my right eyebrow go up at that?
          Yea, what happens if the car is sitting parked in neutral? Go ahead and overheat?
            Ron Jones is a mechanical engineer with diversified experience in automotive design and product development.
            Thats the setup it has now... I was thinking the same thing when its in neutral its going to overheat.
              do you have a link to this kit?
                88 M3 Henna
                95 M3 Orange
                97 M3 Techno
                  $399 for the full kit with fan, brackets, harness, 88* temp switch: https://store.vacmotorsports.com/mob...-m3-p1773.aspx
                  pic installed in my car:
                    I contacted VAC to see if they will sell me just the wiring kit + sensor, without the fan. Waiting on response.
                    I also want to replace the hoses with silicone hoses. Any recommendations? Mishimoto hose kit?
                      there is no magic in a fan wiring kit. some wire. a relay. a bmw t-stat switch. simple and cheap to make.
                      even easier for you. you have it all in place except for the t-stat switch. reroute the "brake switch" wiring to the t-stat switch. done.
                      88 M3 Henna
                      95 M3 Orange
                      97 M3 Techno
                        ^^What mlytle said regarding the re-use of your current setup using a temp switch as the gate control / trigger for the relay
                        As far as hoses go mine are Samco and can be sourced from a bunch of places. VAC sells them for $360 and supposedly have em in stock.
                          I swear you're a genius... everything is setup ready to go like you said! Just need a low temp sensor and I'm all set.
