Rear window seals
  • Rear window seals
    Are the interior rear window seals glued in. Talking about the thick rubber seal that runs around the edge of the rear side window.
    The reason for asking is that I need to replace the rear C-pillar and the front edge of the part is underneath this rubber window seal.
    Or am I missing something... The new piece has about an inch of material on the front edge. So that meshes with the existing piece having its front edge trapped underneath the window seal.
    I am hoping if I have to remove the window seal that it just pops in... but that is hoping and not knowing.
    Anyone replace the C-pillar cover trim piece?
    Petro
    ok got the trim piece in but it was kind of tricky. takes strong fingers to roll back the rubber seal and push the trim piece in.
    Bet there is a special tool that BMW uses.
    Petro
