S14 Operating Issues
  • S14 Operating Issues
    Following a few years of non use because of life and the in tank pump (Walbro) having connectivity issues, a tech friend re-worked the wiring and plumbing for the Walbro.
    Engine started, but ran poorly, like it was on 2 or 3 cylinders so we had RC Fuel Injection Services clean the injectors.
    Injectors installed, the car started, but ran poorly. We stepped away.
    Car sat for a month in my garage.
    Today, a bud and I installed NOS carpet (five hours) and were excited, so 'lets take her out'!
    Car cranked over, but had no interest in starting. Multiple attempts finally got her running.
    We chugged along a short block and hoped that pushing it back was not in the cards, but babied it back with little throttle input.
    • Car runs rough and varies from barely able to remain running to revving with little enthusiasm.
    • Idles rough, applying throttle with no load causes the engine to 'almost stall' and generally has little power (see previous line)
    • CHECK light is on.
    • Tachometer works for a few seconds at start then zero's out almost immediately.
    Input/questions are appreciated.
    "The earth provides enough for everyone's need. Not everyone's greed." Gandhi
    Hi,
    First up replace the spark plugs and report the outcome, I suspect they are fowled and glazed up. Not sure about the Tachometer.
      what is the condition of the fuel in the tank?
      Autobahn Motorsport - Restoration and Service - Portland, Oregon
      503.967.3800
      '72 2002 pickup | '88 M5 | '89 330is | '89 M3 | '01 Z3 M | '11 328xi-t
        Fresh after the fuel pump work.
          Hi,
          The issue is erratic, I'd imagine bad plugs would be perform poorly, consistently. No?
          Plugs have less than 4k miles.
            But it sat for years with old fuel in the lines/injectors? Need to have them refurbished or pick up a set that are.
              Are you sure its running on all 4 cylinders?
              FWIW, I purchased a set of injectors from another member on here, and had them shipped directly to RC to have them cleaned and tested. No real reason to, but since I was redoing the whole fuel system, figured it to be a "might as well" thing.
              I popped them in after receiving them and the car ran worse. 1 of the injectors wasn't even firing. I threw the old ones on and haven't messed with it since.
                The check light shouldn't matter but if you want to know what it is look at the overhead check panel.
                What's the condition of the battery? A failed battery can cause issues and *might also be related to the tach not functioning correctly.
                  Solid spark on all 4?
                  Each injector getting pulse width?
                    Were the injectors just cleaned or fully tested as well?
                    Check for spark on each plug, might be your ECU (especially if you jumped it recently...they get fried easily). Check your grounds.
                      How are the fuel filter and fuel pressure regulator? I had a faulty fuel pressure regulator when I first acquired my car and it caused a hard start and poor running issues, which eventually led to no start.
                      Everything's plugged in correctly after assembly?
                      AFM ok?
                      Good luck!
                        It sure sounds to me like a fuel problem. If you didnt just have the injectors cleaned I'd immediately point right to sticky injectors as the first thing to look at.
                        I would tap all the injectors while cranking or running with a screwdriver or something, look at the FPR, the fuel lines, fuel pump(s), the fuel injector harness.
                        My gut says there is something going on in your fuel delivery. At least if it were me, thats where I would start my investigation.
                          I hesitate to trash a company, but years ago I sent a set of injectors to RC for cleaning and balancing. When I got them back, car ran horribly. After some frustrating troubleshooting (because I assumed injectors were all good) I finally learned one of the allegedly freshly overhauled injectors wasn't even firing....just continually dribbling fuel.
                            Also, if the gas was bad...it could have damaged the fuel system even though new gas was put in.
                            My tank had a bunch of crap in the bottom of it that trashed a brand new pump. Had to get a new tank/pump/etc...
                              Thanks all, there's a lot to examine and I have work/life to deal with as well. Does the tach issue point to anything to do with how the engine runs? Where does the tach get it's signal?
