Wondering for those who run shim under bucket if there is a maximum thickness for the valve lash cap. I am swapping cams with a smaller base circle while keeping the same valve length and need a thicker valve lash cap (range 4.4-4.65mm). Before they were 1mm shorter.
Will going thicker increase the risk of the lash cap slipping out or rocking out?
