Finally have the time and space to reawaken my 89 M after a 6 years or so. I had done a fair amount of upkeep and deferred maintenance before garaging the car back then with ~130K miles. Car cranks like a champ but doesn't fire. As all of the ignition and fuel bits have about 3,500 miles on them I figured I'd start with fuel because of age. No fuel seemed to be getting the to plugs as they were dry, but sparking. I pulled the FPR at the rail and it seemed dry.
I pulled the fuel filter and there was residual pressure in the lines because one of them was leaking pretty good! The gas seemed clear as the day it was pumped in. Both the filter and the damper seemed unobstructed. There was no blockage in the hard line to the fuel rail or the return line to the tank. Bench tested the external pump and it moved fuel as did the lift pump in the tank, though I was only reading 9.5 volts at each while cranking. I swapped in a new filter and will test fuel flow to the engine next.
I certainly wouldn't be surprised to have some plugged injectors but I can't confirm until I have positive fuel pressure in the rail. Happy to have any other words of wisdom added here. The hope is to get it to a friends barn to pull the engine and refresh it while I get in line for a gentle cosmetic refresh of the exterior.
thx
thx
