Will Sanden AC comp. clear DTM pan?
    That compressor looks huge and the worrying thing is the the three bolts that old it on and two are small 8mm size
    • proctor750
      proctor750 commented
      Editing a comment
      Yes it uses the factory sized M8's and one M10 (Came with 10.9 but could upgrade to 12.9 if you wanted) just ilke the stock bracket does. The compressor is similar in dimension to the stock unit but feels lighter weight. I should have weighed them when I had the chance. The stock bracket is actually much less beefy and much too large to allow a DTM pan to fit beneath.
      I actually upgraded conrads's pan baffle bolts to grade 12.9 with tapered heads that act as integral washers. This was due to my fear of the buzziness. Red loctite on those as well.
