I've been trying to chase down an issue with my audio system where there is static/crackling at all volumes. The noise is only in the front channel. The volume of the noise doesn't change when you adjust the volume on the radio, it's at a constant level.
Here's a video of the issue:
Things I've tried:
I emailed Doctor Don, explained where I'm at, and asked for advice. He responded with only 2 words "check speakers." While I don't have a problem doing that it feels like a waste of time, so I'm not sure I want to take his low effort advice. It seems to me that the issue is somewhere in the amplification stage since it doesn't change with volume.
I haven't chased the wiring under the dash. I suppose that's the next step. I've been putting it off because working under the dash is such a PITA. When I do get under there I'll be looking for the any splices a previous owner may have made, and try to find and check the ground.
If I do decide to try swapping out the front speakers, is there an aftermarket speaker that is a direct fit?
Just wondering if anyone has had a similar issue.
As an aside. I don't even use the radio, but it it bothers the shit out of me me that it doesn't work.
Things I've tried:
- Sent the head unit into Doctor Don's for a refurbish. He replaced all the caps and said that he bench tested it and it is working fine.
- I pulled the amp and replaced all capacitors and a couple of resistors
- Replaced the amp with used unit that I got from mwagner10702 (Thanks Mark)
- Checked and cleaned the ground under the rear seat
- Took a good look at the wiring behind the head unit, It's not hacked up and looks to be all original.
