Bumper Stripe Decals
  • Bumper Stripe Decals
    Anyone know a good place to purchase the m3 red bumper stripes from? I believe the following part numbers are correct:
    Front center strip: 51 14 2 233 024
    Front left strip: 51 14 2 233 025
    Front right strip: 51 14 2 233 026
    Rear bumper strip: 51 14 2 233 023
    looks like i can find the rear and front right, but not the others, thank you!
    could be that i have a set left, will check that tomorrow
      If Markus doesn't have any, you could buy from Kassel. Not OEM but they have good reviews.
      BMW E30 M3 Bumper Tape Set - Kassel Performance
        Another option if Markus doesn't have any is these guys, sometimes a bit of a wait but always comes through and the quality is excellent.
        Reproduction restoration decals stickers & warning labels for your classic BMW including E30, E24 E28, Alpina, M3, Hartge and other models
          3M Super 33+ electrical tape. They have it in all colors.
            That electrical tape looks okay, and I have it on my track car, but it's narrower than the OEM stuff. If you want it to look right you need OEM or one of the reproductions.
              You have to be looking VERY close to notice that difference
                Bitch. I have some in the garage. I'm gonna go measure it.
                  have checked and i don't have one, but my local BMW dealer have 1 in stock
                  But price is a bit strange, these 4pieces are 105 Euro
                      make sure you start at the balls
                        Here's a pic of the red Scotch electrical tape next to OEM. The difference in thickness is 3.5mm, which is what Adam's mom tells me he is taint to tip.
                        The issue I've found with the electrical tape is that because it's narrower you have to be careful to apply it straight. It has a tendency to wander in the groove when you apply it, looking uneven. To get it straight you need to pull it taught while applying, but because electrical tape is rubbery it will stretch, as designed, when doing so.
                        The other problem is shrinkage, ask Adam. Over time the tape dries and shrinks, especially if you've stretched it while applying, this causes the ends pull back and the edges roll and lift.
                        Otherwise it's not a bad solution. The color is a good match and it's easy to come by.
                          well done
                            Thanks everyone! man, didn't have notifications on and purchased some of the 3m and it looks alright. going to have to reach out to Markus
