Well, after bringing the new to me car home, filling it with some gas and taking it out for a couple drives to open it up, the car on a cold start the next morning really doesn't want to idle, is super rough, and dies on its own, or if I give it any throttle it will die also. If it can get warm through that phase it seems ok. I'm already literally hitting the reset button and going to replace all the sensors and typical items like spark plugs, coilpack, Tstat, water pump, 02 sensor, new rad cap, coolant temp sensor, upgraded timing chain tensioner, fuel damper, filter, and regulator, new EVO3 injectors, and throttle position sensor.
The one weird thing is the TPS on the car currently is part number 0280120319 not the correct 13621273277. I have no idea why this TPS is on their. My car is a 2.5L build, but I don't believe that has anything to do with it. Would this different TPS cause running/idling issues? I would assume so.
I get a little coolant pushing out the overflow tube when the level is correct and the car is just idling up to temp, but coolant reservoir doesn't seem to be pressurized the next morning after a drive (aka blown head gasket), as recent compression and leak down numbers are great. I know the symptoms sound like an intake leak or something along those lines, so will check all that too, but wanted to make sure this 319 TPS wasn't used for a specific reason that I'm not aware of. Going back to OEM TPS part, and probably going to just pay the high price for the Genuine BMW part, unless using the aftermarket 13621273277 parts is totally fine as well.
Thanks in advance for any input.
