Fuel pressure at idle and wot
  • Fuel pressure at idle and wot
    Hi all, I am still chasing a fuel issue and can’t find the specs for psi at idle and wot?
    Original thread was here:
    Hi, wondering if anyone knows how I can test my AFM. Having issues and I suspect it may be the cause? Background: s14 rebuilt about 6 years ago to “mild” 2.5 specs, didn’t go all the way to 95mm cylinder bore. AFM was a remanufactured 2.5 from ECS. Car has ran great until recently. Just went for a drive and
    I had originally suspected AFM, but put my old one back on and no change. Tested the TPS, and as HANDBLT and hardtailer thought, it was not good. I had a used spare, but unfortunately one failed continuity at idle and the other at WOT!
    So, I am going to order one, but was wondering about the FPR, hence my question regarding pressure. I am getting about 42 psi at both idle and WOT, doesn’t seem right to me?
    Also, when I pull the vacuum hose off the FPR, I can definitely feel vacuum, but the pressure only changes about 2 psi, does this make sense?
    Just wondering if I should also order a FPR while I am at it?
    Thoughts?
    As always, thanks for the help and suggestions, you guys are great!
    Don
    Don
    1973 - 2002
    1988 - iX
    1988 - M3
    Stock is 43psi at WOT and a bit lower under vacuum, if memory of driving around, with an FPR gauge on the windshield, held down by a wiper is correct
      Thanks HANDBLT looks like mine is spot on with what yours was!
      Don
      1973 - 2002
      1988 - iX
      1988 - M3
        Close examintion of the FPR might have the pressure rating painted on it. It will be 3 bar with atmospheric pressure at the manifold pressure compensation nozzle.
