Ground Control Complete Coilover System Pre-Order
  • Ground Control Complete Coilover System Pre-Order
    Hi folks, I’m sure many folks have seen that GC has come out with a complete system for the E30 M3. Currently on pre-order till the end of September for $2,400-ish. Any thoughts on these? Sounds like prior GC setups for the E30 M3 have been well received. As seen in other threads, haven’t seen any review of the KW kits but these seem like a worthy competitor.
    Introducing our BRAND NEW and HIGHLY ANTICIPATED E30 M3 Fabricated Complete Coilover Suspension System!   The days of donor strut housings and strut tube modification are now behind us! There are ZERO cores required for this kit. No more searching for cores to send in for modification, this is a complete, standalone, d
    TheHunter,
    Welcome to the forum.
    Can you tell us more key Technical futures on this All-Brand-New E30M3 GC.
    Regards,
    Anri
    E30M3
    E28M5
    E24M6
    E24M6
    E24M6
    E24M6
    E31840Ci/S62.
    • mlytle
      mlytle commented
      Editing a comment
      did you read the link?
    miytle,
    Yes I did. I am seeking for more details but seems like no other key features are employed.
    At $3000 makes me think.
    Regards
    Anri
    E30M3
    E28M5
    E24M6
    E24M6
    E24M6
    E24M6
    E31840Ci/S62.
      I don't have any insider knowledge, but here's what's posted on the site:
      • Spindle geometry updated specifically for lowered E30 M3's.
      • 35mm more travel than OEM E30 M3 dampers.
      • Relocated and optimized locations for the lower control arm & tie rod, improving bump-steer tenfold.
      • Steering arm is integral, allowing for a true double adjustable strut insert, eliminating the need for a reservoir or a modified steering arm. This kit replaces the steering arm.
      • Absolutely zero modification of rare stock parts.
      • This kit is 100% reversible.
      • Significantly stronger then OEM strut housings.
      • OEM 15" wheels will still fit flawlessly.
      THIS KIT INCLUDES THE FOLLOWING:
      2 Ground Control fabricated struts with single adjustable Koni strut inserts adjustable strut inserts.
      2 Koni single adjustable rear shocks
      1 Pair front Camber Plates.
      4 Eibach Springs or Ground Control Springs produced by Eibach
      4 Ground Control bump stops (made in Germany)
      2 Rear ride height adjusters.
      1 Pair rear upper shock mounts (urethane)
        Placed an order today. Springs: 440lb front / 650lb rears. GC custom valved Konis, and street camber plates. Review to follow but build and ship time is estimated 4-6 weeks.
