I'm glad everything is fine with your engine now. So, what are your initial thoughts? (i'm sure you still have a while to break in??) Worth the money? I hope it was everything you expected it to be and more!
97 Porsche Carrera S
13 Audi S6
SOLD 03 Audi RS6 daily
GONE 88 E28///M5 project
like everybody else wants to know, what did you have him do? I want to do my own, but after talking to him a couple of times, i'm thinking of letting him undertake my car:borg:
they are not idiots.
I'll let Mike give a full list, but it rivals most/all motors on this board with the exception of EVOIII, and I still think he is running hotter cams in his S14 than whats in your "puny" S14.
It's a 2.5L with a fully forged 11.35:1 bottomend, lots of head work, really hot cams and all the good stuff. It's a race motor, intende for 100+ octane. I'll let Mike tell everything else.
not sure if youre referring to Jefrems motor.
Jefrems motor has 13.5:1 compression and 284/276 cams
with alpha N and DTM intake, dry sump, and numerous other
things. the head work im not sure about.
the cams are not that hot, which does make his power impressive.
Wow, a dry sump to extinguish all those thoughts of losing an engine to oil starvation That is awesome. Hey John, does having a dry sump provide any hp/tq advantages, or just insurance against oil deprivation?? Thanks.
13 Audi S6
Originally posted by SeattleE30///M3 Wow, a dry sump to extinguish all those thoughts of losing an engine to oil starvation That is awesome. Hey John, does having a dry sump provide any hp/tq advantages, or just insurance against oil deprivation?? Thanks.
Dry sump systems typically give you about 2 - 5 % better engine efficency. So figure at least another 10 hp on a built 2.5 S14 motor. Excess oil around the crankshaft in a wet sump can get on the shaft and cut horsepower. Some people claim improvements of as much as 15 horsepower by switching to a dry sump.
In a wet sump, turning, braking and acceleration can cause the oil to pool on one side of the engine. This sloshing can dip the crankshaft into the oil as it turns or uncover the pump's pick-up tube.
Dry sump's rule.
I just wish the NSX had a dry sump.
Hell the E39 M5 has a factory semi-dry sump system.
The problems he had were unrelated to the engine- i just wanted to add that. The shop installing the motor also installed anextensive list of other chasses-related mods.. when leaving the shop the radiator apparently gave out, but i don't know the details. I think it was just coincidence that it failed when leaving the shop.
