Hi,
On te E30Zone Forum, which some of the other UK members of this Board also frequent, a Member, Glenn, is currently fitting a E39 M5 Engine and Box into a E30 Shell.
While that is no mean feat in itself and has accumalated quite a following, and is now up and running, I could not help but noticing that he has installed E36 M3 Front Legs onto the project vehicle.
He has achieved this as a straight bolt on exercise,with the only modification being the E30 top mounts replacing those of the E36.
I am curious to know if their are any benefits or gains in this respect for M3's ?.
He has also fitted E36 M3 Front Calipers and discs, which have forced upon him a 17'' diam wheel. [These are still the clasp type calipers, and very heavy]
Given that these front Struts were bolted staright on, and appear to widen the front Track of the vehicle slightly, something that the M3 strives for, it does start to open up many questions.
For instance, if using E36 M3 front Struts as the core leg, are any suspension set up's available that otherwise might not ? are Big Brake Kits easier to come buy [secondhand] , does wheel offset change to make differing wheels more accessable ?
Give that a lot of E30 owners have nabbed standard M3 front legs for 5 stud conversions, and that many existing ones are exchanged for coliover set ups, standard front legs are not as nearly as common as they were, so are these a possible option ?
There just maybe some real gains out there for small money at the end of the day.
Regards,
The Gorilla.
Regards,
The Gorilla.
