m5 oil cooler?
  • m5 oil cooler?
    does the m5 oil cooler fit our cars? if so which m5? 34 28 or 39/
    I was looking at doing the same thing, but I believe it requires some modification to fit. I would just stick with the stock oil cooler since it cools the car well enough.
    Bryan K.
    Texas A&M Formula SAE
      thats koo. i needed to replace mine anyway. ill just buy a used one. thanks guys
        Camptown racing uses an E28 M5's cooler... You could call them to see how they worked it.
        http://www.camptownauto.com/mpower/cars.htm
          thanks magnus!
            MAgnus,
            You gotta Love Gary Bossert! He may not always be the most pleasant guy to talk to, but he does know what he knows!
            Guys have been using the M5 oil cooler for YEARS folks. If you track the car in the hotter climates like Road Atlanta, Sebring etc. in august then you will probably want one. I use the stock oil cooler and have never seen temps above 245 on the worst days.
            Then again I live in SUNNY Connecticut!
            :rolleyes:
            Upgrades are easy and the finished job looks factory installed.
            If you are not track driving, then I would invest the $ in something more useful.
            Eric
              I have been wanthing to do this for a while now, can some one post their oil temps after adding this cooler?
              I know it's a doubble row cooler, it's supose to be about the same size, and you need new AN lines for it. Maybe you can also install it so the cooler lines are not so much in the way of the oil filter?
              Do not click
              At least it's German
                I had to fix it.
                http://www.s14.net/memberpics/bryan.jpg
                  I had to fix it.
                  HAHHAAHAHA...gangsta....
                    Wow, that is awesome! I have a new sig now You should have put a little copyright symbol in the corner and put your name , you still can if you want!
                    Thank you so much Magnus!
                    Bryan K.
                      look at the gr.a exchanger setup....
                        iigomotiv sells an M5 cooler kit:
                        http://www.iigomotiv.com/ProductDeta...?productID=407
                        -Han
                          gr. a exchanger
                          John,
                          Could you describe the gruppe a exchanger?
                          Tyler
                            well,
                            I have an m5 oil cooler for $200 if anyone wants it
                            perfect condition
