I'm removing the head on my car to change the head gasket and everything is going fine, but the only problem I'm having is I can't seem to figure out how to remove the fuel injector wiring harness. The Koala E30 repair CD only says to "lever up injector harness" but it doesn't say how to disconnect the plugs from each fuel injector. They don't seem like they will just pull apart because there are two retaining tabs on each side of the plug, but I can't find any sort of release tab. Anyone know how you disconnect them?
Need help removing fuel injector wiring harness
Originally posted by Bavarian3
I used two pictures of the harness from the repair CD. Ignore the green arrows in the pics.
http://www.geocities.com/mpowerede30/pictures.html
In this photo is the harness... four injector connectors and one extra connector.
That is the main connector on the harness. From what I remember all we did was removed that one connector and lifted up. Let me know if that does not work and I'll take a look again. I believe with the injector connectors, you have to push them in and pull up.
The harness cover should just slid off, at least ours did.
The Koala CD photos are small....
