Bolt Size?
  • Bolt Size?
    Yesterday, while I was under to change the trans oil, I saw a bracket that bolt to the trans from the exhaust was hanging without bolt to the trans. Does anyone remember the bolt size? TIA
    It is a flat bracket that goes from the exhaust header to the trans.
    Ryan
    Born date 01/88
    Ryan
    Never mind, found it. M8 K11x35. Thanks.
    Ryan
    Born date 01/88
    Ryan
      thank yourself
        Thank RealOEM.com
        That place is amazing as well as S14.net (do you know where is it?, :-))))
        Ryan
        Born date 01/88
        Ryan
          I am looking for this bolt which is NLA. What size is this? Metric 8mm, 35mm length, but what is K11? That would be a weird pitch. Can anyone shed any light on this?
            k11 denotes a bolt with a partially threaded shank. the non-threaded bit is a specified to offer a tight fit similar to a dowel.
              Hardtrailer,
              Thanks for the info. Much appreciated.
