euro vs us cooling system
  • euro vs us cooling system
    Whatsup fellow s14 enthusiasts
    So I couldn't keep my hands off of my winterized car and decided to do something to it while it was sitting. I ordered the lower temp fan switch (80/88) and replaced the one on the thermostat with it and took the fan clutch with the shroud out of the car.
    What I am not sure about is this. If the euro models had a similar setup (no fan, just electric with lower temp switch) why is it that many members on this board have installed and additional electric fan on the inside.
    Is there any reason why I should go the extra mile or what I have now will work just fine
    p.s. spring is getting closer and closer!!!
    zhpregistry.net
    Hey Noro...whats the part Number for the lower temp fan switch, or did you just adapt one?
    I wanted to get around to this mod as well. Have had (driving a Merc 560 SEC 300 miles for a frend... bang, ouch) bad experences with these fans flying off :(
    Steve
    (For business related questions please contact my other user name '[email protected]')
      this guy
      Part # : 61 31 8 361 787
      zhpregistry.net
        I use a 91/99 on my car and its the correct one. I only have the Stock front mounted electric fan.
        Andrew
        [email protected] | H23-is | S14 | Ceccoto #270
          Re: euro vs us cooling system
          My car sees track events when the ambient temp may be approaching 100*F
          I'm not using an extra fan, but mine is wired so that the thermostat can switch it on any time it has to.
