Part Number Euro AFM
  • Part Number Euro AFM
    Anyone have the correct part number for the Euro 2.5 AFM?
    Seems BMW changed the number recently.
    TIA
    Mel Abrahams
    Abrahams Motorsport
    www.abrahamsmotorsport.com
    isnt it the same as the m30 afm?
      Not sure about that.
      Mel Abrahams
      Abrahams Motorsport
        Hi Mel,
        Here are the partnumbers for the Evo III AFM.
        Bosch # 0 280 203 027
        BMW # 13-62-1-286-064
        btw that is the same part number for E28 and E34 535i and other M30 engines.
        Mark
          Thanks a lot
          Mel Abrahams
          Abrahams Motorsport
            Originally posted by mp88m3
            Hi Mel,
            Mark
            i knew it was the same as the m30 afm.
              Just found out that BMW changed the part # to 13-62-1-286-349
              Mel Abrahams
              Abrahams Motorsport
                How much does this AFM cost? How big of a difference is it from the US model? I don't know much about the Euro model, but I'd sure be interested in freeing up my motor.
                Will
                -Jeremy Clarkson
                  Dealers charge about $395 for the Bosch.You should be able to get it for less from other resources.
                  There is another brand for about $100 less.
                  Mel Abrahams
                  Abrahams Motorsport
                    Will
                    It's the same size. The big differance is it has a better resoultion and is made for the 2.5l motor. It will give you better throttle responce, better part throttle and just make the car better to drive. You also need a new chip with it. So your best bet is to also get the E3 injectors and the Jim C chip.
                    Do not click
                    At least it's German
                      Quite right Evo111M3-going to install the Injectors (expensive little buggers!) and AFM next week-hopefully this will take care of the fuel starvation problem.2.5l JC Chip is already in.
                      Mel Abrahams
                      Abrahams Motorsport
                        It's the same size. The big differance is it has a better resoultion and is made for the 2.5l motor. It will give you better throttle responce, better part throttle and just make the car better to drive. You also need a new chip with it. So your best bet is to also get the E3 injectors and the Jim C chip. [/B]
                        Just to clarify if you have a 2.3 and you want to run the euro AFM. you need
                        1. a 2.5L chip
                        2. a set of evo3 injectors?
                          Not sure if it will work with a 2.3l-don't see why not-I have a 2.5l.
                          Mel Abrahams
                          Abrahams Motorsport
                            1. a 2.5L chip
                            There is no gain on a 2.3l, it's more of a driviability thing, then a HP thing.
                            Do not click
