Guys,
I still have not solved my engine issues post winter-storage:
The engine isn't really 'knocking' so much as rumbling at idle and througout the rev range. It sounds like a friggin chopper or even a mustang (blub blub blub blub blub).
What would cause this sort of rumbling? I have checked all my ignition components and replaced the battery. The fuel pressure is in the right range (~42psi) and I'm debating on draining the tank but this rumble is spot-on consistent so I really have a hard time thinking it's bad fuel.
Plugs were slightly fouled (fuel) after a long idle - which is normal for the S14 from what I've read - but I have new ones ready to go in if that's the problem and the plugs still looked fine before and right after all this started.
Despite the relatively consistent psi, could a faulty FPR cause this sort of rumble?
Thanks for any help. The nice weather coming around the corner is gonna drive me insane if I can't go out and drive like I'm insane...
