If all the spark plugs look consistent then it's not a leak at the header.
The leaking header will run leaner than the other cylinders.
Also check to see if the muffler has blown out/or leaks.
Mine blew out from the front side of the muffler, not the back as I had assumed. So check the side where the center section connects to the muffler, the welds broke on mine where the pipes were welded to the muffler.
