Anyone have part numbers for the aux fan switch?
  • Anyone have part numbers for the aux fan switch?
    I have the schematic but can't read the little numbers on the actual switch to determine what's what. Does anyone know them or have a good picture of a new switch? Thanks in advance!
    From the factory schematic:
    Pin 1: Brown, ground
    Pin 2: Red, High speed
    Pin 3: Black, blower resistor, normal speed
    Let me know is these are what you were looking for.
      OK, the heat was getting to me Saturday. What I am trying to determine are the pinouts on the switch as shown below so that I can connect the correct wires to the correct pins. Thanks in advance.
        ok I think these are what u want:
        Pin out from dual temp switch:
        1.) Green/Black, pin 1, to fuse, should be hot in run position
        2.) Black, Pin 2, Normal speed switch, closed at 196 Deg. F
        3.) Black/Brown, Pin 3 High speed switch, closed at 210 Deg. F
        If this is still not what you need let me know and Ill keep checking.
          I need to know which pin on the connector is pin 1, 2, 3. Thanks for the help.
          Cheers,
          Nick
            Just now figured out what you were asking!
            Guess I was really tired last night
            A=1
            B=3
            C=2
            That should do it
              You're the man. Many thanks!
