Just installed urethane motor mounts
  • Just installed urethane motor mounts
    All I can say is: wow!!!
    Out of the box, the bright yellow motor mounts from Ireland Engineering measure 5/8" shorter. Compressed, they should lower the motor by 1/4". It took only one hour to install them. Then, the test drive. The car feels more planted without the motor moving around. Is it a placebo effect or the engine sitting lower? Perhaps. Nonentheless, there are no extra vibration, except that smooth feel of every piston going up and down. It is more a purr than a vibe. Great stuff for S14 lovers. It feels so good, so connected to the engine without feeling annoying.
    Overall and after only a 30 minute drive, it is very satisfactory improvement over the rubber mounts.
    Nice summary Lee, too bad I already have new stock mounts in as I would have considered these after that testimony.
    Ash
    Sold...
      Lee,
      Sounds very good. What are you using for transmission mounts?
      Petro
        Originally posted by petro
        Lee,
        I use e24 tranny mounts. They are stiffer than M3 mounts but filter vibrations.
          Good news. I wanted to use the IE mounts but was concerned because something about their gemetry, I forget. I didn't want to use the 750 mounts which I bought because I didn't want to move the motor down AND back or sideways. Can you give a quick rundown of how you changed them? I thought it was an involved process...
            How to change motormounts
            Should take less than one hour, even for noobs.
            Raise the front of the car, and secure it with jackstands under the frame rails. Use a pair of 2 x 4 to avoid damaging the frame rails. Use the floor jack to slightly lift the engine (from under the oil pan) by about an inch, no more. You should use a piece of wood between the floor jack and the oilpan to avoid scratching it.
            Let's start by the passenger side.
            Use a 17mm socket and an extension to undo the mount's bottom nut. Undo the four 13mm bolts that attach the aluminum bracket to the block. Slide the assembly out from underneath. It is time to check for any oil leak or perhaps even clean the side of the block (I use wd-40 and a brush). With the motormount assembly out of the car, remove the three 10mm bolts that attach the heat shield to the bracket. Using the 17mm socket, undo the upper nut. Install the urethane mount, and proceed in reverse for this side of the car.
            And now for the driver side.
            On this side, you will need to remove the rubber intake below and possibly the oil filter. First, undo the mount's bottom nut and the four 13mm bolts that attach the alloy bracket to the block. The 13mm lower left bolt is not easily accessible with the oil filter in position. Remove the motor mount assembly from the top, this time. Swap the urethane mount but leave the upper nut, loose. Especially if you have those subframe reinforcement gussets that do not leave much place to insert a socket from underneath. Reinstall the bracket, properly torque the four 13mm bolts onto the block, and install the lower nut. By leaving the upper nut loose, it may be easier to wiggle the urethane mount until you can easily install/torque the lower nut. Lower the engine and fasten the mount's upper nut using two extensions and possibly a swivel. Lower the engine. There should be ample clearance between the engine and the subframe/steering rack.
            It is time to go for a test drive.
            The engine will seem more present, but not because of vibrations, more from a lower frequency emanating from every piston going up and down. The engine sounds a bit like it has a carbon fiber airbox.
              Thanks! great writeup for the archives
                Plus, you saved $ 100 bucks!
                  Great write-up Lee! Thanks for the accurate description of how-to, I'm storing it for my own use later on.
                  :OMG:
                  random musings
                    I have IE motor mounts and have been nothing but impressed with them!
                    www.Sports-car-restoration.com
                      I don't know how y ou guys do it, these things translate any and all road hazzards into the cabin.
                        so the engine is a road hazzard now?
                        Thinking of subframe bushings?:p
                        -Eric
                          There must be something touching the shell. Perhaps the tranny mount have been twisted, or the exhaust is touching. On my car, let's say that I feel the motor a bit more, but nothing major. Just a deep and soothing vibration. It was a great mod.
                            Any update on these, after some time driving around on the IE urethane mounts?
                            Would you do it again, given the choice?
                            Motorsport 16v
                              I went with stock tranny mounts reinforced with silicone and IE motor mounts and it was indeed better... I think both IE tranny and motor mounts was overkill for the street on a smooth track I could imagine it would be fine.
