Originally posted by mjcalabrese
Matt
There is a low pressure switch, a high pressure switch and in some cars an a/c temp switch that are in between the evaporator temp regulator and the compressor. If one of these are open the compressor will quit. Look for where the 12v stops when the compressor quits. Compressor operation has nothing to do with coolant temp.
Mark
Matt
Mark
i do agree on how to test the system. when the compressor quits, pull over and check voltage at the low pressure switch, high pressure switch, and the coolant temp switch. if any of those three are open, the compressor clutch will not engage. this assumes you have a good compressor ground.
the evap temp sensor will also disengage the compressor if the temps get low enough for the evaporator to freeze
