E28 front wheel bearing swap
  • #31
    Hey Tony
    I have replaced wheel bearings (and rings) trackside many times. It is not too involved. You need the big 46mm socket or SAE 1-13/16". Use a Heavy Duty breaker bar and a long jack handle. Torque on that big nut is 250ft.lbs
    When you pull the bearing from the spindle, chances are that the bearing cage will separate. You can either cut it with a grinder (if you are in your warm garage), or gently chisel it out (trackside).
    When you reisntall the big nut, don't forget to hammer the sleeve in the notch to lock the nut.
    • #32
      Cool info! Thanks for share.
      In the little OT side, the rear discs are interchangable with the e28 rear discs for the M3? Since many stuff came from the e28, wonder if it will bolt on. I don't have e28 rear disc here to test.
      • #33
        Sweet.. Uwe as ever you are a hero. Looking to replace mine and low and behold you have the answers again.
        Wonder how much they are from BMW? Or whether just to stick with GSF/Euro
        Sterling M3 project..
        • #34
          I have used the cheapest GSF bearing in this pictures. Was (and still is) fine for more than a year on the Ring (to my own surprise)
          The suspension legs I am running now are with the most expensive bearings C3 could get me. Was keen to have a set of SKF. You may want to check for price at CENTRAL AUTO SUPPLIES as they the sole importer for SKF in the UK. Or just ring Kirby at C3 and tell him you want the same bearing he sold to me. Can't remember the price top of my head, but they are at least double what the cheap GSF bearing are!
          • #35
            Excellent, I shall call them tomorrow..
            Time for a full on suspension/drivetrain refurb..
            Looking back the GSF hubs look very roughly cast.. Are the C3/SKF ones any better?
            • #36
              I don't get it. How come they only sell the bearing with a new hub? Why not just the bearing like on the rear axle? Seems like collectively there must be a whole pile of perfectly good hubs lying around. What am I not getting?
              • #37
                business decision. ..where in mi are you located.. are there any mich get togethers specifically for e30 m3s?
                • #38
                  Novi. Never heard of any get togethers. Where are you at?
                  • #39
                    A2
                    • #40
                      the hub forms the outer race of the bearing. There is no single bearing to replace, it's the whole hub you need.
                      • #41
                        A2
                        I used to be in A2 myself until recently. When I get my car back on the road we should meet up one day.
                        Oh yeah, looking closer at the pictures I see that now. Besides, had there been a way for you to only buy the bearing, I am sure you would have found a way, and I mean that in a good way
                        • #42
                          BMW stopped selling cars with separate hub/bearing in 1982 (a quarter of a century ago) with the e12 5 series.
                          • #43
                            Changed my bearing yesterday with E28 M5 bearing, pretty easy job if you have the tools.
                            Made a short video comparing the noise before and after. Available at: http://www.bemarim3ex.com/index.php?...263&Itemid=201
                            Esa
                            • #44
                              i done this 2yrs ago 15000kms still going strong thanks to uwe
                              • #45
                                Uwe, do you have the P/N for the e28 hub assambly? Mine are toasted in the M3 and need econmical replacement!
