how to check dowels on flywheel
  • how to check dowels on flywheel
    hello
    my car wont start ,i want to check if the dowels on the flywheel has fallen out ,how do i check it ? do i have to remove the gearbox ?
    thanx
    M3 GOTTA LOVE THEM
    IF you remove the "inspection plate" you can rotate the front crack pulley to check the to make sure the trigger is still there. I doubt this is your problem :(
      well i hope it is because i have checked fuel and spark and air and have all,its the injectors they wont spray and i have fuel in the rail so i think its not getting a signal from the dme to fire.
      M3 GOTTA LOVE THEM
