engine stumbling at low revs while taking off
  • engine stumbling at low revs while taking off
    Today my car started stumbling badly in the 800-2k rpm range almost everytime I would pull away from a stop. It even stalled 2-3 times while doing this. It seems like a fuel or maybe even an ignition problem but I can't find anything wrong under the hood. It accelerates and cruises fine once the rpms climb above about 2k and idles fine as well, so anyone got any clues?
    Speculate that it might be the throttle position switch.
    Either needs optimal adjustment, or is getting old.
    Mine has a very light bog,once or twice, just as the throttles are opened on step-off. I put mine down to a lean stumble when it is grannied.
    m.
