Door opens lights stay on
  • Door opens lights stay on
    when I open the door on the car the interior lights turn on but then when I close the door they never turn off. The wierd thing is that if I put the light switch in the position where it will turn on when the door is open it will stay off untill I open the door (as it should) Does anyone have any ideas as to what the electrical gremlin is and what parts I need to replace???
    Pull the door switch on both sides and make sure they are free of corrosion. These feed the lights with the ground signal.
    Tony
      IS the switch that little nipple looking thing on the front of teh door frame?
        Yes, it makes contact with the metal of the car when opened sending a ground signal to the lights, and door dinger thingy doodle......
