Fuel injectors/flow rate
  • Fuel injectors/flow rate
    Very new to this forum and would appreciate any info or experience with replacing fuel injectors. 1 s not working too good after a good soak in carb cleaner. Other fouled injector was cleaned/opened up using this method. Also what is the flow rate of stock units? TIA.
    Stock 2.3 is 240cc/min. 2.5 EVO had 300cc/min ones.
    Dave
      Sent them to cruzinperformance.com. Best $50 you can spend for your injectors!
        i also used cruzinperformance and am very satisfied with the results. great company to work with, very easy transactions.
          Hey Baxter E30... if you send a friend's injectors.. do they ever come back ? :rolling:
          I've used cruizin several times... excellent work.
          Mark Williams
          Dallas, TX
            tapping on them with a socket extension can help loosen up a stuck injector, but the best thing is to send them out if they are high mileage or haven't been used in a LONG time
            James
