7pc External Torx Socket Set E6-16
  • 7pc External Torx Socket Set E6-16
    Anyone know where they sell these over the counter?
    No time to order... Trans here Wed. New seals Thurs, install Fri.
    7pc External Torx Socket Set E6-16 $14.07
    http://www.pelicanparts.com/catalog/shopcart/TOOL/POR_TOOL_CAT040_pg2.htm
    Plan to slip in a new trans while my car is in for exhaust work while the exhaust is down.
    Its just going to be a quickie, will not disturb the hyd clutch or need a trans alignment tool. Just swapping the trans. Getting the tools together and realized I do not have the above sockets.
    Would anyone who has done this more times than they care to remember
    jot down a quick tool list? I believe I have everything but the above mentioned ext. torx sockets. It will just make it easier if I bring my own / right tools for the job.
    Thanks!
    Auto Zone had 'em. 4 piece set E8, E10, E12 & E14.
    As I recall those looked like the right sizes.
    Cant imagine needing anything below E8, but will I need the E16?
    Thanks!
      I got a 6 piece Facom set from Ultimate Garage a few years ago. Ask Steve to overnight. Not cheap, but excellent quality.
      Mike
        Thanks, what sizes are needed on the trans? E16? or just E12/E14?
        :thank you :thank you :thank you
          I bought mine from Wal-Mart for $20, made by Stanley, and last forever they don't strip like Snap on.
            i dont think i ever stripped anything with my snap-on but the inverted torx set was 130.00
              I know Sears has the 10-piece Lisle set.
              Mike
                [QUOTE=Bennetts22;222226]i dont think i ever stripped anything with my snap-on but the inverted torx set was 130.00[/QUOTE
                the snap on set has a tendancy to run a little small causing stripping, i'e cracked quite a few bits as well.
                  "Thanks, what sizes are needed on the trans? E16? or just E12/E14?"
                  Got the trans today. Looks good (aside from the input shaft sticking out of the box & clean red oil all over from the vent)
                  :o(
                  Stamped Numbers 003115ACM
                  Cast # 262.0.0510.90 _____225 ___2.3
                  Sound about right?
                    I think I've seen that same set at sears for around the same price IIRC.
                      Anyone know what sizes are needed on the trans/bell housing?
                      (trying to save a special trip under the car to find out)
                      Have E8/E10/E12/E14, will that get 'er done?
                        I think you should be o.k. with that assortment, just make sure you have long extensions. I have 24-36 inch extensions which are 3/8 on the front and 1/2" for my impact gun.:jakeguita
