Hi all!
Engine is being rebuilt at the moment and have cams with the following numbers on, how do I tell exactly what they are?
4791 - Exhaust
1890 - Inlet
Also, on a complete whim (!!) bought the following camshaft on eBay (description at bottom of post)...on reflection the description confused me somewhat, i.e. it mentions it's a Schrick 296 (11.2 lift, I think) when I thought they did a 292?
Keyss questions are: -
- Would I need to pocket the pistons to use this cam? The engine is being re-built with Evo 2 pistons.
- Stock or uprated valve springs?
- Will it work with cams I have or am I going to have to purchase another? I'm sure (sort of!!) that I've read a 292 on inlet would go well with a 284 on the exhaust? (The head on the car is going to be flowed plus at the moment I only have a standard exhaust manifold on there with a modified system, manifold will get changed pretty soon though! I'm running an Emerald ECU and Uprated Injectors (some shade of green I think!))
I have read lots of the posts on cams and I know that it's all very subjective, just want to understand if what I've got will work or if I need to spend some more to get a better solution...
Thx,
- Andy
Ebay advert description in German: -
"Biete eine Motorsport-Nockenwelle " NEU " für einen BMW M3 E30 2,3 -2,5ltr. und 320is Motor Typ S14, mit 296 Grad, 11,2mm Hub, 102 Grad Spreizung, auf der Nocke sind noch die Zahlen 745 und 1099 eine 4 und die Buchstaben BMW und ein Dreieck abgebildet."
And a rough translation via Babel Fish: -
Offer an engine haven cam shaft "NEW" for a BMW M3 E30 2.3 -2,5ltr. and 320is engine type S14, with 296 degrees, 11,2mm stroke, 102 degrees of spreading, on the cam are still the numbers of 745 and 1099 4 and the letters a BMW and a triangle shown.
4791 - Exhaust
1890 - Inlet
Thx,
- Andy
